hehe i just dont like to assume much
ok as to the subs cutting out this will happen with premier subs when you are distorting the hell out of them turning the gains down was the right thing to do.
since your subs are single 4 ohm your running a 2 ohm load for 360wrms .
each sub getting 180wrms you will get decent boom but you would be better off with either two of those amps each sub getting 250wrms@4ohm or one amp that will do closer to 800wrms @ 2 ohm .
and as always set your gains right with a dmm the tutorial is in the subwoofer section
