Problems with Dims and Skips
Mash Jetta TDI
Im having problems with my system, my head lights dim and the CD skips. I figured that it was because I didnt have enough juice running to the amp(which pulls 1500 watts). I added a 1 farad cap, but it still dims out and skips.
If I add another cap, or switch to a 3 farad cap will it help out at all, or should i go the route of a 1200 watt battery under the hood or a better alternator?
Also, I am having trouble with my subs bottoming out when i push them. Here's what im running......
4 gauge amp kit
1 farad cap
Box with 14"H x 6"W Ports on both side.
MTX thunder 8100D amp
2 12" Alpine DVC subs at 2 ohms per voice coil (wire parallel)
Blaupunkt san jose deck
Blaupunkt CD changer
If anyone could make any suggestions it would be a great help!
Thanks
Chris
I had that problem in my old mustang until I beefed my alternator(75amp to 140amp) & got a bigger battery(660amp to 770amp)...that & if you're running a stinger cap it's over rated on it's power...that worked pretty well for me...but I don't know enough to say that it's all you'll need
Alternator is a much better solution to dimming than a cap.
Skipping is usually due to a shitty HU, not voltage drops.
Your subs probably bottom out because of the huge ports in the box. Use a different box or turn down the power.
thanks guys, Good idea on the box, I didnt even think about that. What kind of box do you recomend then? That alternator is going to be tricky, I have a VW Diesel and not a domestic, so upgrade parts are very hard to find. If any of the VW people know something that will help out I would appreciate it very much.
1998 Jetta TDi GLS
Thanks
Chris
try a fully sealed box with out ports...I know it's a little off beat for a lot people but it could be what you need in this case or you could try insulating the box with poly fiber like they use in pillows to slow the air flow a little...stuff it like a it's a chick with no tits
Mash Jetta TDI
Mash Jetta TDI
Illinois USA
Mash Jetta TDI
