(Probably Stupid) Thiele-Small Specification Question
urwhatueati8god
He tasted like chicken.
187
NJ
I have all the specifications for the subwoofer that I'm using and am mapping out what size the box should be. The question is when doing the calculations, does the volume include the port volume or does the port volume need to be added separately? Sorry if this has been posted before, but I didn't see it anywhere in the thread.
That has nothing to do with the T/S params, but your volume should be after all displacements (sub, port, bracing). If your box is 4 cubes gross (total), your port takes up 0.75 cubes and the sub takes up 0.25 cubes then your net volume is 3.0 cubes
You might want to consider learning a bit more before designing/building your own enclosure if this has you tripped up. But the net volume is after sub/bracing/port displacements are subtracted. The gross volume is prior to displacements being subtracted. Every manufacturer's recommendation that I've ever seen is a net volume. And, generally, the manufacturer is recommending the smallest possible size. Most subs like much more than the recommended. And, fyi, this is not a t/s question.... I was directed to the pro designers on this site after attempting this myself when I knew nothing about the subject. They were right to do it, so I'll do the same. Hit up a pro, man.
I would, but alas it's not for me; it's for my stupid and cheap cousin who won't spend any money on any pro guidance for his installation.
This is part of the industry..Just one of the parts that we didn't have.. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
urwhatueati8god
urwhatueati8god
NJ
Kangaroux
vegang
vegang
