Pro Audio Amplifiers ( 1000W+)
Eldorado
Banned
*EDIT* Thats 1000W, not 100W
I might be putting my TC 1.5HP 18 inside my house and id like to know what pro audio amplifiers you guys think are good quality and cheap.
Sofar ive looked at behringer EP2500, yamaha P2500S, Nady XA1600,American Audio VLP-1500,samson SX1200 for possible candidates
Id like to keep it in the $300 range. Crown doesnt really have any $300 ish 1kw amps.
look into the qsc rmx series. we run them at my work and they are very reliable. i would recommend the crown i-tech's but they are way out of your budget.
One amp, one woofer? What is the woofer impedance?
Do you fear buying used proamps? if not, check ebay, lots of stuff if you
aren't in a hurry.
If you plan to drive 4 ohm bridged, then RMX1850HD is probably the best
bang for buck, fine one used.
If you plan to drive 8 ohm bridged, the EP2500 might give you the best
bang for buck in this situation... because
EP2500 is RMX2450 clone with smaller transformer which gives less power at lowest
rated impedance.
RMX1850HD = RMX2450 but has lower power supply rail voltage, hence lower
power rating and it won't go into thermal protect as quick, hence the HD {heavy duty}
moniker {Lewinsky}.
aren't in a hurry.
rated impedance.
moniker {Lewinsky}.
TC 1.5HP 18, only comes one way //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif ( dual 2)
I checked ebay, didnt find a whole lot.
or im either looking wrong
sorry to thread jack el,
but hey fellas, you know that piece that you can add onto amps that power subs in sealed boxes?? i forget the name of them but they help lower the f3 of the sealed boxes. my question is how low do they go?? in other words, i heard ppl say you can add this to the amp to drop the tuning down to such-n-such Hz ( usally 20Hz) but can you go deeper than that??
sorry to thread jack el, but hey fellas, you know that piece that you can add onto amps that power subs in sealed boxes?? i forget the name of them but they help lower the f3 of the sealed boxes. my question is how low do they go?? in other words, i heard ppl say you can add this to the amp to drop the tuning down to such-n-such Hz ( usally 20Hz) but can you go deeper than that??
Linkwitz Transform?
Fancy EQ.
When you EQ, you will push more excursion and draw more power. There is
drawbacks.
I'd rather just make a ported box if your woofer of choice allows.
TC 1.5HP 18, only comes one way //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif ( dual 2)I checked ebay, didnt find a whole lot.
1 ohm or 4 ohm.
Aside from plate amps, if proamp, you do 4 ohm wiring and run the proamp
in bridged mode. That would be sweet.
Ebay keyword searching
EP2500
I see many listed. Cheapest, buy it now for $255
QSC RMX
RMX2450 buy it now $425 {used}
.. a few more
RMX1850HD - buy it now for $379
http://cgi.ebay.com/QSC-RMX-1850HD-Power-Amplifier_W0QQitemZ7420093703QQcategoryZ23787QQrdZ1QQcmdZViewItem
If your budget is higher, more choices.
Linkwitz Transform?
Fancy EQ.
drawbacks.
there we go //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif bought it up cause i want to know how deep these can extend the frequency of your sub. plus, with a ep2500 or something along those lines, i think that would be enough power for a sealed, no?
1 ohm or 4 ohm.
EP2500
QSC RMX
.. a few more
thy, can u hook these up to a regular 5.1 receiver? do you just hook it up to the 'sub out' on the back of your receiver?
You need a receiver with a pre-out that's full range. Sub outs rarely have the option of full range audio..... but if you wanted to just hook up a pro-audio amp AS a sub amp it would work well.
really?? just hook it u like u would a plate amp?
Eldorado
Banned
Eldorado
So Cal
Beat_Dominator
