prices JL SI ID
shoulda done your your research before buying
I did
Question/Opinion: How will these sound with my Kicker 1200.1 mono class D amp? I have decided on gettin these. Soon as my bonus check gets here Ill be sending you the money.
Can I paypal?
-Nick
That amp will work well. I am pretty sure I looked it up before and it said it was 1 ohm stable. If it is 1 ohm stable and will give you around 1000rms then you will have a perfect amp for the mag.
Ben
I assume you have had plenty of time with each of the three drivers?
you are planning on running each mag of a kx1200, not running them both off the amp...correct?
How the fok did I get a neg for that?? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You'll want something that does 1500+ watts at 2 ohms or .5ohms. Does it matter if its new or used?
Did you get 12s or 15s?
No it doesn't. But I don't want to buy cheap chit either. Guess you can tell that.
I also don't need to make another mistake. I am sure Ill be very happy with the SI. I just hate surprises like this.
If I need to buy another amp Ill have to sell this one. But Ill look into the going prices first. Then set a price.
I will help you out. When I replied to you I said it would give a mag around 1000rms which would be perfect. That amp puts out around 1000rms at 1 ohm. The problem is you won't be able to wire 2 of the mags down to 1 ohm. Don't worry, we will work everything out.
more like 1400+ at 1 ohm
nickm
nickm
houston,tx
Showrides
