Prerunner trucks...
Just about anything can be covered under bolted/welded on, trucks are much easier to work on than cars too (least in my opinion) Those Ford rangers your showing are using modified TTB (Twin traction Beam, 4wd term) setup suspension. Bolt on kits for even 4wd trucks with this supsension can fairly easily get 14" of travel. Most of them you show are 2wd though but the setup and geometry is mostly the same.
Also the ones you are showing are probably mid level modified, can make a prerunner (or prerunner styled truck) for much cheaper than some. That trophy truck will cost a helluva lot more than $20k for a chassis. I think a rolling chassis for a baja low grade trophy truck is up around $100k.
I am guessing the ranger is a pretty good platform for these, I know I have seen lots of yota's too out there. But ranger seems like it would work good, I'm sure the desert shops have bolt on long travel coil over kits and axle beams for the front end, convert it to a healthy 302 V8 from a mustang with a C6 or so ***** and a 8.8" axle from the mustang and should be doing pretty good. For the looks department get a prerunner bumper (or light bar since its pretty much all they are) and maybe some fiberglass fenders
I'd love to pick up a Ranger or Tacoma with some front end damage for relatively cheap and rebuild it into a basic 'out in the desert for the weekend' truck.
That would be ideal.
I built one out of a 82 caprice station wagon once. It was sweet. Had like a 6ft lift on it and could pwn anything out there. They banned me for life from racing and outlawed station wagons from competition.
sounds like a solid plan, should make for a good jumper, light front end with lots of travel and then tons of power is pretty much the equation for a prerunner if I am not mistaken.
My buddy from high school had a tacoma that he dropped 15k into. King triple bypass , supercharged, etc. let me drive it out in glamis one weekend and it was really sweet! theres nothing better than flying 100+ along some dunes with some air conditioning and music haha!
Loud3
OG
Loud3
Trampa Bay
DanM7890
