precision power
azimuth
funded*by*soros
got the precision power pc2350 today. hooked it up on site to my 2 type r 12's before buying. holy shatner!!! beats the crap out of the viper d1200.1 i have my alpines (dual 4) in a single box wired at 1 ohm. looks like i'm going to have to wire this thing in 2 ohm stereo, unless someone says different. when i tested it we had it wired at the current 1 ohm and the gain about a quarter of the way up.
he said i could run it at 1 ohm, but the specs say different. looks to be only 2 ohm stable from what i can find. the controls i'm going to have to figure out, with the four buttons to play with. not sure yet how they work.
Amp is only stable to 4 ohms mono(1400x1). Take you DVC 4's and run them series-parallel(run the coils on each sub in series to make an 8 ohm load then run both subs in parallel to get down to 4).
A manual for the later generation of that amp is here(PC21400)
http://www.phy6.net
once there navigate to the audio page, then to the PPI page, then select the powerclass manuals. open the manual for the PC2400, 2600, 21400. That should give you all the information on the amp and what the various buttons are for.
azimuth
funded*by*soros
azimuth
Denver, Co
noonej21
michigan born
    May 14, 2026
michigan born
    May 14, 2026
