PPI PCX 1500D PCX 4125 info
They are great amps. From 2004 i believe. They do way more than rated power and will drop below recommended. I had a pcx 2200 brdged it. Rated at 800 rms @ 4 ohms, i dropped it to about 2 ohms and never went into protect did get a little warm but thats about it.
Description:
Precision Power PCX-1500 Mono Amp:
Expanded system flexibility begins here with the PCX Mono and Multi channel amplifiers. Whether you need a mono, four channel or five channel amp, PCX amplifiers give you limitless system configuration potential. At the heart of all of the PCX amplifiers, is the TC-X crossover. The TC-X crossover allows complete control of the frequencies from 30-4KHz, HP/LP/Full. On the multi-channel amplifiers, you have the front channel crossover acting as a 2-way, tracking crossover. What this means during installation is, by sending the crossover front channel signal to the rear channel, you now have the ability to Bandpass the rear channel. Every limitation has been eliminated from the PCX Line of amplifiers... What else would you expect from PrecisionPower.
Features
Channel: 1
RMS Power Ratings
4 ohm:
500
2 ohm:
1000
Bridged:
na
Damping:
>500
S/N Ratio:
>110dB
Power Input:
4 Guage
X/O Freq.:
30Hz-4KHz
X/O Type:
2 way
Cooling Fan:
Yes
QBass™
This Amplifier Incorporates some or all of the following features:
· New! Advanced Instrumentation Input stage
· New! 12dB/Octave; HP/LP/FULL; 30-4kHz
· Independent Line Output Crossover 30-4kHz
· Fully regulated PWM power supply
· Triple Darlington Output stage
· AM V Protection circuitry
· Forced Air Thermal Management
· QBASS Plus™ Bass Boost
· High Voltage Input Capability With Input Attenuation Switch
· Gold Plated RCA Input and Output Connectors
· PowerLock speaker and Power Wire Connection
· Completely Designed and Handcrafted in the USA.
Specifications
Power Bandwidth
20 Hz – 20 kHz
Total Harmonic Distortion
Input Sensitivity
150mv – 12volts RMS
Input Impedance
10k Ohms
Load Impedance (stereo)
2-8 Ohms
Supply Voltage
11 – 15 volts
Damping Factor
>500
Slew Rate
>50 V/μS
QBASS PLUS™
Up to +18Db Boost @ 30, 44 or 60Hz
Crossover
12Db/Octave
Subsonic Crossover Frequency
5-80Hz
Idle Current
2.0 Amps
Continuous Output Power
500 watts RMS x 1 @ 4 Ohms per Channel
1000 watts RMS x 1 @ 2 Ohms per Channel
* ALL POWER RATINGS SHOW ARE TESTED @ 12V; 20-20kHz
Dimensions
Length - 25”
Height - 2.375”
Width - 10”
Fuse requirements: 100 Amp
.......taken off an ad on eBay for the same model.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
