ppi 900.4 lpf not working?
Bought the amp about a month ago brand new from sonic electronics and I have been running it on a pair of comps up fronts only using Ch 1 and 2 in full. Finally got my woofers and tweets in and wired up to run active. I used channel 1 and 2 for the tweets set the hpf with the button clicked in to 4000k. Then the woofers on band pass(ch 3,4) with the lp on about 70 to 80 hz, then the high pass with the button clicked in at 4000hz. Turned the radio on and no sound from the woofers. It will work on full but not bpf on the rear channel. I even switched up ch 1,2 and 3,4 still can't get the bpf working. Anyone got any suggestions will be appreciated.
do you have the x1/x10 knobs set incorrectly so that you're completely bandpassing the signal down to essentially 0?
edit; yeah you do. run the subwoofer channel with the HPF set 20-30hz and LPF set at 80hz
think about it, HIGH pass filter, LOW pass filter. HPF at 4k for a sub will cut(ok, attenuate for you smarties) ALL frequencies below 4k.
I have my hu's front and rear rca's Going to the ppi 900.4 for the tweets and mids. My head units rca's is going to my twisted 1.8k. I'm sorry I may not fully understand your reply. ^^
sorry i was confused, you're trying to bandpass your active midrange drivers. try this, put the filters for your active midranges on HPF only set to 100hz and see if you get output
i think you're using your filters backwards. hpf at 100hz and lpf at 4khz. the other way around and it will cut all signal. the underlying problem is a HPF at 4khz will cut all signal to your speakers below 4khz, a LPF at 100 hz will cut all signal above 100hz, so what signal is left? lol
read this: Electronic Crossover
Yep you were right I was running them backwards. I want to make sure I got it right, ch 1 and 2 (tweeters) on hpf set to 4k. Then ch 3 and 4 (mids) set to bpf with lpf at 4k and the and hpf at 100. I know mids are right what about the tweets ch 1 and 2.
awholelotofnutz
sc
CSCStang
