PPI 900.4 in protect mode
jesse55
The amp has been going in and out since i got it. it worked for about a month and just the other day it starting working when on accessory (12v) but when i turn the car over it goes into protection. ive tried turning head unit off before starting its not voltage spike. the amp i had in place of it worked perfectly in the same wiring. i just unplugged all speaker wires and rcas and it powers on but when i pug in an rca it goes in and out of protect. someone please give me some trouble shooting solutions i can try. is the amp defective? also all speakers are at 4 ohm i tested with ddm. im grounded right to battery in the trunk.
The next step I would take is to plug in a different RCA cable from a test source. I like to use a 3.5 mm stereo to male RCA audio cable between my phone and an amp for this test. You could also just plug in a different, known good, RCA and see if you get a solid green light. If you have an RCA that is shorting out that could explain the problem.
ok so plug speakers back into amp and use a new set of rcas plugged into phone.
Are you saying you don't have a separate ground run from the amp to chassis?
yes the battery is in the trunk so i grounded stright to battery neg is that a problem?
I'd see it as one. You really need two separate grounds; one from your battery to chassis and a separate from your amp to a different chassis ground. I've seen this screw a lot of people over when this step is missed.
jesse55
jesse55
Long Island NY
Firebird 1991
