PPI + 12w6 ? for zane.
MinionStax
N.Y.
Hey thank's for your reply and help, the only problem is that the PPI A1200 says 2-8 ohms for (stereo), and 4-8 ohms for (bridged) so I want to know is their any other suggestions you have for the JL 12w6 subs. Let's say I got another 12w6 what could be then done using this amp, I've heard that the 12 w6 subs run great with 3 but then what would the ohm's be. Just for the knowledge, what would be an insane amp for the 2 sub's, I dont like MTX or other's along that line. Again thank's
I would look into MA audio but they kind of make thier stuff specifically for thier own stuff. But I am about to buy myself a nice MA system for christmax I am going with the HC2502 it is 2500 watts and i am hooking it up to 2 12 xls and i am going with that amp so i would if i was you but i dont know how much watts those subs take?
Well, you could run the two as they are or at 6ohm mono then. Otherwise, the only other better option would be to add the third sub as you had said. You can wire 3 W6's at a 4 ohm mono load. This is something that is typically done with several successful installs.
As for MA Audio- I highly suggest to steer clear of them. They are just a re-vamp of the ultra low line Mobile Authority, ANABA, Thump line. Nothing but cheap low quality, unreliable, junk. I would hesitate to use a piece of thier equipment for a wheel **** on my car. Just a word of warning about this brand based on my own experience and reading.
Take it easy,
-zane
go to www.jlaudio.com they have all the possible ways to hook up any speaker configuration you want. Later
MinionStax
MinionStax
N.Y.
Emmick
