528hz
Everything'sMiscellaneous
Well, the 04 XXX is up and running and I've got the American Bass VFL 150.1 powering it for the moment. I'm very impressed with this amp and the XXX......well, jump on the bandwagon everyone because everything you've heard and more about this sub is 100% true. Now, I've set my gains with the DMM, but since this amp is rated at 150x1 @ 4 ohms, the EXACT RMS of the amp has been up for debate, but I have went by the fact that this thing will do the 2000x1 @1 ohm. This is kind of long and detailed so bare with me.
Here is my box & electrical setup:
2 Batcap 800s
stock 650 CC battery
150 amp, stock Bosche alternator
2cu @ 33 hz
Hers is my predicament:
I used a 50hz test tone to set the gains on the DMM to 42.42v ( theoretically 2000 watts) the first time. The volume on the HU was on 67/80 After I set the gains, the sub was moving great, but it still felt like it needed more power.
So the second time around, I adjusted the gain by ear using the same 50 hz tone and same volume level. I could actually hear when the amp started to clip, because the amp itself would start to sound like it was reving up, so I knew when to back down off it. I set it to where the amp the made no "reving, clipping" sound and hooked the sub back up. It was a hell of a lot louder the second time
After I set it by ear, I put the DMM back on it and I got a reading of 53.1 (2800+ watts)!!!! There is no distortion or clipping (listening by ear) coming from the sub unitl almost full volume, but this didn't make any sense to me. There is no way the VFL does that much power.
Are my gains way too high or is this amp not making enough power? The XXX feels like it could take 2500 RMS according to the RMS consensus on the VFL.
2 Batcap 800s
2cu @ 33 hz
