Power Wire
subzero
~~~~~~~~~~~~~~~~~~~~~SOLD OUT~~~~~~~~~~~~~~~~~~
Red 1/0 gauge power wire from Knu, 2 twenty foot lengths.
Black 1/0 gauge power wire from Knu, 2 twenty foot lengths.
New Never Used
Sales are pending....
Free shipping to lower 48
REF: EriCCirE, morlac
http://www.caraudio.com/forums/buyer-seller-feedback/504152-subzero.html#post7492301
Kolossus Copper Aluminum Kable (KCA Kable) has arrived! The KCA Kable uses the same ultra flex PVC found in the Kolossus Fleks Kable and the Copper Clad Aluminum (CCA) conductor from the KLMX Kable. Copper Clad Aluminum (CCA) is made up of 90% Aluminum and 10% Copper. CCA overall provides a cost effective solution to most audio systems. Assembled from stranded 34 gauge CCA, the KCA Kable is equal in size to the Kolossus Fleks Kable, but is designed for lighter current loads and not lightening your wallet. By using an area of 66.88mm^2 of CCA, the cable is nearly equal to 2/0. This over sizing offsets the use of the CCA compared to standard sized 1/0 made of OFC. So you get equal performance and at sizable savings.
I think you will be just fine to be honest. Id run it and check it after hammering on it quite a bit and check the temp on the wire by hand to see...
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Oh, total opposite. i play with storage bins full of wire scraps from past installs for fun. I hoard decent grade wires from audio homies...
972
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
subzero
subzero
Chandler, AZ
TWiZTiD859
    May 16, 2024
    May 16, 2024
