Power Wire
wolfman1966
Help, I need help with running a 4gauge power wire on a 2004 Dodge Neon. I might be able to run it through the harness where all the wires come through but there's not much room there, or maybe I will drill a hole, but I'm kinda afraid of doing that, cause I don't know what I might hit.
Anyone on here ever run the power wire in a Neon? if so, please help.
OnBoard Diagnostics. Its the plug under the driver's dash where the technician plugs in the diagnostic computer and can monitor the car's performance. Crawl under the dash on the driver's side. It's right above the hood release.
You can do it without taking out the driver's seat but there are only 4 15mm bolts that hold the seat in. It's a 2 min job to get it out. and another 2 to get it back in. Slide the seat all the way back and take out the front 2 bolts. Slide it all the way forward and take out the rear two. Center it and lean it all the way forwar to make it as compact as possible to get it out the front door. Close the rear door before you move the seat in or out of the car to keep from scratching the door.
wolfman1966
wolfman1966
WEST MONROE, LA
helotaxi
