power wire question
I have a 94 EX it should be the same for you
Look on the drivers side up in the top left. There should be a little rubber circle with some wires already going through it. You can cut a hole in it with a knife or razor blade
Get some pics and ill circle it for you if you still cant find it
ok thank u i will try that and let you know:)
Not 100% but if its like my 1999 civic ex then the batt is on pass side and then the fuse box is on the left, take out batt, take out fuse box and there is the harness hole...Should be big enough to fit 1/0 through it... At least mine is...
bsean63
Undead Revolution
bsean63
ohio
romans535
