Jason Eden
Hi i have a 89 mazda it has a 55 amp alt. im going to get a 120 amp alt for it. Im going to be running 1 saz 1500 and 1 sax 100.4 I have some 0 ga. wire i can run to the back.
1. do i need to run 0 ga. to both amps or can i run 0 ga back to the rear the split to 4 ga. ?
2. do i need a separate small battery " i was thinking a yellow top " in front then a small kinetic in the rear or should i just get 1 big kinetic like 2400 or something
3. if i only run the one up front can i run 1 0 ga. to the rear then split off to each amp with 4 or 0 ga leads ?
thanks for any help im new to this and im trying to buy all the stuff i need a peice at a time because i dont have a ton of money,
