Power vs amps
  • 3
rocktrep
Hello everybody,
I'm looking for an amp about 500 W. One amps request a 120 amps fuse and the other one only 50 amps. The first one deliver 600W and the second 500W.
I know efficiency can be a little bit different.
But how an amps can produce 500W with 50 amps and the other one only 600W with 120 amps.
Note: first amp is from Xtant and the other one from Jl Audio
Any comment will be appreciate.
Rock T.
I like my 3.5K hidden under the driver's seat. Nobody knows where my equipment is. Always thinking it is in the bed of my truck. Nope. Two amps...
14
When you do find a new Ground spot look for something existing that is tapped. If nothing like that is available make sure you cleanthe area to...
13
3K
There’s no question that that setup wouldn’t bump like hell. Those SALT amps are killer. If the new Origin subs are as good as the ETA subs were...
4
Run 4g for power (or 1/0 if you can). There is no downside to bigger wire, and you won't have to replace it if (when) you go bigger. Speaker wire...
908
rocktrep
rocktrep
Québec, Canada
iwantmorebass
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
