Power setup any good?
los33
Car Audio G
Im still building new setups and plan to see if this would be fine..
At the moment i want to push between 2.5-5k watts, but currently got another gmc sierra to test on same 2000 year of truck.
I was thinking:
-Singer 270amp 6phase hair pin alternator
-XS power d3400 in main battery spot
-XS Power D3100 in secondary battery spot
-1/0 ofc big3
-either 2 runs of 1/0 to dist block or single 2/0 to dist block for amp (only sub stage)
Would this electrial be on par?
Might also in future purchase alt brack to have stock alt run truck stock lights and all, then the singer amp be dedicated to the car audio.
2 + and 2 -. Honestly I don't think it's needed. I've pooped fuses because I ran out of 300s and I didn't notice.
Aslong as you were running a 300 amp alt or lower a 1/0 ofc should have been good enough, but anything over i know 2/0 is better.
But in my case i prob will be doing 2/0 from the battery since ill be doing over 300 amps to amplifiers. The battery and alt all should be good with 1/0.
los33
Car Audio G
los33
Houston, TX
los33
BP1Fanatic
BP1Fanatic
