Power Runs
Jeremy M
If i can only make 2 runs of 1/0g from front battery to back batteries. should i:
A.) Run 2 positive runs to the back
B.) Run 1 negative run and 1 positive run
I'll be running 2 batteries in the back. One on each side of the car in the rear.
I hope it's not too late, but with the limited availability of power wire, I would run both runs positive from front to back. BECAUSE, assuming you properly ground the rear batteries to the frame of the vehicle, it is better than running it all the way up front. With out a doubt, better. Not as easy, but better. There would be less resistance on the ground this way, and more current making its way back. Also, big 3.
Jeremy M
Jeremy M
Moxee, Wa
Enellz
michigan born
    May 14, 2026
michigan born
    May 14, 2026
