Power keeps cutting out to amp
ok the car has not been running and we actually drained the batt. cuz its in the garage and we dont wanna die lol. But we did actally try to do it with rthe car running and that didnt help either. And as far as the dirty fuse, the wiring kit is brand new. and we have tried another amp and are having the same problem.Thank s for your help.
Nice ninja edit, faggot...
nice way to provide no positive contribution to this thread in any way.
And yw blaisen. Like I said, if you own a multimeter, check your voltages. Even if the car is running, you could still be drawing too much, or the battery could possibly even be bad. If you have strong connections on your wiring, this seems like the culprit imo.
Alright i dont own a multimeter but i will try to borrow one and check into all that tonight. Thanks for your help. Its nice to see that some people dont require tit pics for advice. LOL
I was just joking around, man. And I'm not even the only person in this thread to do so. You're the one who had to get all e-tough.
And so what if I didn't help out in this particular thread? I help plenty of people on this forum daily...
Dont get your panties in a bunch I think the only person that took it personal was you. Now run along and go try to insult someone else today. Cuz we ain't takin none here.
You know what i don't ever post on here, But since it sounds like ya need the help , and since no one is asking these Questions , here it goes.
What amp is it?
What sub(s) and Speakers are they?
What Bat do u have up front?
What Alt are you running? what size amps is it?
How did you set the Gains on the amp?
and the last one , What size Power/ground wire?
And to answer your question just from the info i have seen, it does sound like something hooked up to the amp is loose , or a Bad/dirty fuse or the amp could be going out/dieing/dead, oh and from what i heard your bats dead? that could be the reason your amp waz cutting out(Because of the Voltage Drop)
rockford fosgate 1800 soundstream 15's (2) the wiring kit was for 2000 watts not sure on the batt or the alt. we adjusted the gains all the way as usual ill see if I can figure out the others Thanks
Blaisenj1
Blaisenj1
peoria, il
bubbagumper6
