power inverter Q
stangpounder
Wi
well, i want to put my playstaion in my car right. i was looking at power inverters but i cant find one without a cig lighter conection or longer then 3 feet with battery clamps, is there one that i can put in the trunk?
simple if your puttin it in the trunk, cut the bat clamps, ground it in the trunk, and run power wire to the batt, simple electronics
Higher power inverters often come made for direct hookup with 8awg or larger wire...if you don't already have one, might be something to look for. Those are usually the ones with multiple outputs that can run a lot of stuff at once.
stangpounder
stangpounder
Wi
JimJ
