Meh!
Ok, soon I am going to be installing the Crossfire TEK352 amp I have to power some Memphis PRC63 door speakers. Anyway I already have a Memphis PR300 amp. Would it be ok to run 4 gauge to a distro block and have dual 8 gauge out to power my amps. Then use another distro block and have the 8 gauge ground on each amp go into distro, then 4 gauge out and ground it that way? I was told they both needed to be grounded at the same spot and if I could do my wiring this way it would simplicate things a LOT.
So could I do that? Let me summarize...
Powering amps=4 gauge wire - 1x 4 gauge in and 2x 8 Gauge out distro - Power to each amp
Grounding=The ground from each amp(8gauge) - to the 2x 8 gauge spots on distro - to a 4 gauge out to ground
