Power Cable to Battery?
  • 3
not familiar with that specific vehicle but most have a rubber boot where a large group of wires pass through the firewall into the cabin. poke a hole in that and slide your power wire through.
...or just grab yourself a drill and make your own whole in the firewall...just be careful to plan out whats on the otherside (i recommend going from hood -> cabin so you have less chance of drilling through anything important like your master cylinder //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif )
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
https://www.alfaowner.com/threads/147-routing-amplifier-power-wire-through-firewall.1190164/
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
3K
Run 4g for power (or 1/0 if you can). There is no downside to bigger wire, and you won't have to replace it if (when) you go bigger. Speaker wire...
846
Daniel
Caraudio.com
Daniel
SFLA
cyber256
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
