Power cable routing (08 Civic)
Look for a blank black rubber grommet if you can find one and find were it comes threw at that is were i routed mine in a 99 Honda civic. If you can not find one I routed mine threw a existing grommet very carefully stretch the opening in the grommet and slide the wire threw than after that is done to make sure i did not ruin the integrity of the grommet I use silicone caulk to seal it up.
I don't see a lot of options, as the firewall is recessed way back under the cowl and hard to reach. I was hoping someone with this model car had found an "easy" way, but there may not be one!
i just drilled two holes in my drivers floor board behind the kick panel in my 08 Civic Hybrid....then I pushed the wires through from the inside of the car and fished them up from under the hood....I ran a 4 ga Pos and gnd...took every bit of 5 minutes
Any pics?
You went under the car and then up the firewall?
there is a hole already in the firewell but you can only fit 4 guage in there. there is a grommet in the hole so just pull it out and run it through there if its 4 guage. otherwise i had to drill a hole to run my 0 guage through. its not very hard to drill a hole either. oh ya and a a close hanger is a must because there is no way you are gonna fit your had through the engine compartment to reach the hole.
Drilled a hole behind the drivers side kick panel, where the hood release cable runs. Wires ran up inside the framerail right to the battery.....very clean and not too bad once I figured out where to put it.
pegasis50
pegasis50
Richmond, Va
pegasis50
