Power Cable = No power HELP!!
and you doing the " toutch the pos to the neg and look for a sparke and cause the fuse to blow just do you know,, and putt a mutli meter on the fuse check for resestance, even if it looks good some times its not
Wouldnt the power cable have sparked if there was some sort of current running through it when i put it against the chasis
I meant hook the power wire to the battery...lol
Before you blow somethin up I will be serious.
Take your meter and put the positive on one end of the fuse and Neg on the other as if you were checking Ohms(resistance). If you don't get a readout your fuse is bad.
maritoze
Jedi Master
maritoze
CA
Ken448
