marklevinson1
Hi folks,
Been scouring the internet but could not find a satisfactory answer for my dilemma. I have a 97 Nissan Maxima with a power antenna. The motor is fine but the mast is broken and I need to replace it. I have already disassembled the motor housing and fished out the broken end of the plastic gear strip. The problem is the mast part of it. I see that the outermost metal tube runs all the way down into the motor housing and I may be wrong but it appears to be well attached at the bottom. So I would assume that stays put while the replacement mast slips down inside of that. The issue is I cannot for the life of me figure out how to remove the old broken mast from inside the outer tube so that I can replace it. As you can see by the picture I have mangled the old mast quite a bit in my attempts to remove it with locking pliers. I am finding that the pliers, no matter how tight I make them, keep slipping off the inside mast. Anyone with experience or advice who wants to respond to this it would be most appreciated.
thanks so much,
Mark
thanks so much,
Mark
