power and ohms???
azzkikr
Please clear this up for me
What would be louder???
1200 watts at 4-ohms
1200 watts at 1-ohm
My guess is that one ohm is because of resistance but I am not for sure and want to know the right answer. I just told one of my friends that his system wasn't at its full potential b/c he was running the rms power at 4-ohm when he should have tried for an amp that ran at 1-ohm. His subs by the way are dual 4 ohm with 600 rms each.
A 1200 watt amp at 4 ohms will cost more too, since most rate their max rms power more twoards 2ohm or 1ohm... but less resistance the better, technically, since it takes less power to get the desired output, but the amp must be designed for that or "poof" hehe.... home stereo's are mostly all 8 ohm too.
If his amp was one ohm stable, that would work...otherwise, you can't do that. You should run the amp at the lowest stable load impedance.
Like I've said before, only if it's unclipped and from the same class of amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif But that's what's going on here, so a watt really does equal a watt here.
azzkikr
azzkikr
Batesville,IN
chinny
michigan born
    May 14, 2026
michigan born
    May 14, 2026
