Power Acoustik
anaranchi
your mom's hot
the question that has been asked a million times "is this a good deal"
PA2-1200 - Power Acoustik 2 Ch. 1200 Watt Power Series Amplifier'
for $139+shipping
Full Mosfet Power Supply
• Dual Cooling Tunnel Tech.
• PWM Circuitry
• Full selectable crossover Hi/Full/Low
• Three Way Protection Circuit
• 2ohm Stable Stereo
• Tri-Mode Capable
• Variable Low Pass 40Hz-120Hz
• Variable Hi Pass 150Hz-1.5Khz
• 18dB Bass Boost @ 40Hz.
• Frequency Response: 10Hz to 30Khz
• S/N Ratio:97 dB
• THD: 0.02%
• System Distress Indicator
• High/Low Level inputs With Floating Ground
• 4 Gauge Power/Ground Connection
• Gold plated RCA Connectors
• Line output
1200 Watts Max Power @ 2 Ohms
600 Watts RMS Power @ 2 Ohms
500 Watts RMS Power @ 4 Ohms
anaranchi
your mom's hot
anaranchi
tulsa,ok
abcdefg
