Power acoustik tri mode?
lwrddenali
SENIOR MEMBER
ok my buddy has a power acoustik 1920 amp and hes got 3 subs hes lookin to buy im not sure about watts but i know they are dvc4ohms so is there any way to run them subs and get the same about of power to each sub bridge'n the amp. its 2ohm stereo stable and 4ohm mono stable? could u run the 2.67ohm load off the 3subs run bridged to the amp??
FYI, that's not "tri-mode". What you want to do is simply run 3 subs to a single amp. "Tri-mode" is something totally different.
Anyways; I wouldn't recommend it. That amp may or may not handle a 2.67ohm load bridged, depending on different factors. The best thing to do would be to only run two of the subs until he finds a new amp that can safely handle the lower impedance.
lwrddenali
SENIOR MEMBER
lwrddenali
BFE
lifted95blaze
