Power Acoustik rz4-2000d
globalminds_ent
Review of Amplifier:
Power acoustik rz4 2000d
Post name, details and review of the equipment you're reviewing. This forum is for reviews only! No questions should be posted!
Just a heads up about the razor line from power acoustik
SIZE:
I don't have any pic yetvbut this thing is tiny! About the size of one of those flat external hard drives, in thickness and maybe a couple inches longer.
Hook up:
Hooking it up was kind of a hassle you have to take out two screws and use a screw driver to actually pull and flip the end off to see where each wire goes.
What i don't like is the power and ground are on top of each other, and it's too easy to touch the bottom screw, when putting in the battery wire.
I know you would say just put in the top first. The wire actually covers up the the bottom screw.
This does have hi-inputs for you stock hu guys
Why you should consider it:
Overall it has a couple design flaws, the lack of features besides a lpf and hpf, yes has these but it's just a three way switch you cannot set your own fq, also you do not have a bass boost.
The reason why you should buy this amp is because it gets loud! It's rated at about 160 watts Per channel, i haven't clamped it but i think it does all of that 160 cleanly
The sound quality is great never used a full range class d before, but now I'm sold.
PRICE!
For $109 shipped the lack of pre-amp features is not a big deal, this has to be one of the most affordable Korean amps on the market. Yes no Chinese junk here.
WHAT I HATE ABOUT IT:
No preamp features
Design fkaw of the ends
Has an horrendous screeching should when it goes off
BOTTOM LINE:
Buy it, don't waste money on something more expensive. Save weight in your car, it can't weigh over ten pounds.
This amp is a no frills, get loud type get the jpb done unit.
globalminds_ent
globalminds_ent
oxford ms
globalminds_ent
