Power Acoustik PS1-5500D ?????
DDSC
Wang-aholic
Any one know if these amps do true wattage daily
Power Acoustik PS1-5500D //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
5500W Max, Power Series Class D Monoblock Amplifier
http://cgi.ebay.com/POWER-ACOUSTIK-PS1-5500D-5500W-MONO-AMP-AMPLIFIER-NEW_W0QQitemZ120220061455QQihZ002QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Product Description:
Power Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 1700 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 3200 watts x 1 chan.
Max power output: 5500 watts x 1 chan.
Full regulated PWM MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz)
Hi Speed Digital Circuitry
Preamp RCA outputs
4-Way Protection circuitry
Platinum-plated RCA level inputs
Platinum-plated screw terminals
Variable low-pass filter (50-150 Hz)
Subsonic Filter (15-40 Hz)
Frequency response: 15-150 Hz
Dimensions: 18"L x 11.4"W x 2.4"H
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
1-year Sonic Electronix warranty
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 1700 watts x 1 channel
RMS Power (2 ohms) 2500 watts x 1 channel
RMS Power (1 ohm) 3200 watts x 1 channel
Bridged RMS Power N/A
Peak Power Output 5500 watts x 1 channel
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged N/A
THD at Rated RMS Power .5%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 150 Hz
Subsonic Filter 15 - 40 Hz
Signal-to-Noise Ratio 100 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 30A x 5
From what little I understand, expect a helluva lot of current draw and around 2700 rms out of it at 1ohm
I could be wrong though
But hell even then, I've thought about picking up one for a temp install
4gauge power for **** near 3kwrms?that seems a little much..
I suppose its possible, it just seems contrary to current amp design
Considering the price tag and 5x30A fuses I'm going to go out on a limb and say it's WAY more likely that it's just very over-rated as opposed to a marvel of modern electronics, a solution to the world's energy crisis, and re-writing all laws of energy by being significantly better than 100% efficient.
DDSC
Wang-aholic
DDSC
Jackson, MI
MisterGrubbs
michigan born
    May 14, 2026
michigan born
    May 14, 2026
