power acoustik lt 1920/2
nik
how can i run this amplifier to a 4ohm dvc subwoofer?i'm thinking 1 chanel each coil but i dont know if there will be a problem for the sub, the amplifier is not stable at 2 ohm load bridge so this is my problem
Run the coils in series for an 8-ohm load and bridge the amp.... this ensure that you will get the exact same signal to each voice coil.
One channel per coil should work. Just keep your gain at a moderate level until you have tested it that way.
the problem i have in mind is if the 2 channels of the amplifier are not the same i think i will have a problem,what rms power will give at 8 ohm load?
i have this one in mind but do you know how much rms will i get at 8 ohm load?i need 400-500
nik
nik
Greece
nik
