Powder Coating Gun and System. Parker Ionics! Powder coat Baskets, Motors, AMP Cases!
Yes small parts you can use a good home oven.
But I wouldn't recommend you use the oven in your kitchen that you use for cooking food in (unless you like the taste of toxic powder in your food). But you should be able to find a cheap oven on craigslist (that's where I bought mine from...it was $15 because the top glass was shattered). Bump for an awesome gun.
Needs to be convection or it will **** things up. Ive tried. I now have an Oven from harbor frieght out in the shop //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif:veryhapp://content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Thanks for pointing that out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif lol
U can get like 4' ovens now days cheap as well from what i have heard, we built ours. But there is LOTS of options for the oven, just needs to be like 350 degrees or so and even heat all over..
I've had no problems with the regular oven I use (it's not convection). You just have to be carefull how you position the parts so they are not too close to the heating element (or you will burn the powder...had that happen one time).
correct ours was like a regular oven just much bigger. We built ours so racks could roll in, it had a element on the bottom, and back of the oven with a swinging door on the front, we could get 2 24" rims or a full motorcycle frame in there easy.
RetroAudioinc
Custom Car Audio Decals
RetroAudioinc
Indianapolis, IN
RetroAudioinc
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
