Possible to emulate an cd changer? and help to understand cdc wiring
piphansdk
Hello there!
As a lot of others out there having the Fiat stilo, and maybe another bunch of cars, i really would like to understand how CDC's are working in order to find a fix on how to install a aux cable on the cdc line, where the radio is activating the CDC options if it is present.
I need to find out, how it would be possible to emulate an CDC without buying the expensive tools out there. i have a wiring diagram of the stilo here:
Ofc. i understand c17, c18 and c19 and belive that emulating the CDC would be to short 2 of the other pins or to ground one of them... could someone help me here? and maby explain the use of the other pins? another diagram is found here: FIAT Car Radio Stereo Audio Wiring Diagram Autoradio connector wire installation schematic schema esquema de conexiones stecker konektor connecteur cable shema
piphansdk
piphansdk
Denmark
Snapper_Slapper
