Ported Right? ( For the BoxBuilders )
danteBirosel
* Cerwin-Vega V-Max VMX-15DVC *
Quantity: 1
Parameters:
Fs: 17 hz
Qts: .47
Qms: 9.80
Qes: .50
Vas: 7.1 cu ft/ 202 liters
Xmax: 20.3 mm
revc: 3.68 ohms/coil
rec sealed box: 2.0 cu ft
rec ported box: 5.0 cu ft, 30-32 hz
I really don't know anything about all this stuff so i want to hand this information to the pros. I own a 1994 Nissan Pathfinder and i have alot of space in my trunk. I will post tomorrow the dimensions of the available space i have. I am looking forward in a Ported Enclosure.
Btw, If you are a box builder, and up for the challenge i will be happy to pay someone to build me a box.
Please post your comments/suggestions/questions and i will get back to you guys asap.
Thanks Alot.
When you get the available dimensions, I'll help you come up with some plans, and then I can possibly build it for you, I need dim's before I can help you at all though.
Hey man thanks alot for the help.
Here are the dimensions that is available:
Width = 30 inches
Length = 38 inches
Height = 16.5 - 17 inches
These are like the max available space. Basically anything in between the dimensions should work perfectly.
Thanks alot.
danteBirosel
danteBirosel
San Diego, CA
danteBirosel
