Ported enclosure sounds "funny"
Dred
I build a new enclosure of 2.5 cu (a.d.) tuned to +/- 28 hz.
Slot ported vent, 2*15 inch and 29 inch long.
So far everything looks okay but ...
When playing my favorite tunes the sub sounds like its in an "undamped" enclosure.
Experimenting with the foam to damp the enclosure didn't got me anywhere.
it's missing low-end like my old sealed delivered.
Am i looking for something that just isn't there?
Or did something went wrong ... ? //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
thanks for the reply in advance
Dred
Sorry ...
Its a 15" brandless sub since there's no name on it.
Specs:
Z-Nominal Impedance in Ohms : 4
Fs=Free Air Resonance Frequency in Hz : 28.6
Qts=Total Q Factor of Driver : 0.52
Vas=Equivalent Acoustic Volume in Cubic Feet : 5.8
Xmax=Peak Linear Displacement on Cone in Inches : 0.15
Ref=Driver's SPL 1W at 1m in dB : 90.3
Dred
Sorry ...Its a 15" brandless sub since there's no name on it.
Specs:
Dred
Looks like a sealed box woofer to me....which would explain why you are having such problems with it ported. High Q, low Fs and EBP likely in the 50-60 range (though you didn't list Qes). That's textbook sealed enclosure right there. Only thing going against it (sealed box wise) is the anemic Xmax figure.
I'm sure it isn't port noise/airleaks.
Some songs are missing notes but only real low ones
it plays "real instrument music" really nice though.
I know its not the ideal sub, but the Xmax figure made me deside to try it ...
have to try my first ported enclosure with something
Dred
Tommorow i'm gonna try it isobaric,
maybe the enclosure is to small like Jmac says.
thnx for the reply's.
Keep you posted.
grtz.
Dred
I'm not really sure what an isobaric configuration is going to give you, other than higher power handling and more linear travel/less distortion...also, why aren't you using the second sub already? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Do you mean inverting, not isobaric?
Well, you're correct...that's a classic clamshell isobaric setup.
Still not sure how you'd think it would solve your problems...you'd still be looking at two drivers that won't do well in a ported enclosure. Only now it could take twice the power and have less distortion due to cone excursion.
well i was thinking of it like this:
a classic clamshell isobaric works well in half the size enclosure of 1 sub.
its all an experiment, i was very happy with the sealed setup but wanted to try something different, something new.
Dred
Dred
Dred
europe
amartin_72
