ported downfiring enclosure.
So it does not matter if the subwoofer is mounted on the same side the Port side #2 is?
I was not sure if that effected the tuning in any way.
Not quite sure what you are asking... If you are asking is it okay to have the subs mounted on a different face than the port, then yes... that is okay.
I used to believe always put the port on the same face as the woofer, and still pretty much believe this for an SQ system... For SPL/SQL i don't feel it is necessary.
David12460
David12460
Minnesota
David12460
BP1Fanatic
BP1Fanatic
