Well, that would have to be compared with over 8 different designs to match response curves and check for excursion control, phase control, power limits, passband and efficiency curves, etc first. But if you say BP is your goal, I recommend a quasi 6th BP, but that would be limiting your possibilities without knowing for sure the sub will work well in that type of box, if at all. SO, no real answer can be given without testing first. Because of this, the only answers you may get is volume and tuning recommendations because nothing else can be said for nonconventional designs without testing and calculation. Sorry, I wish I could pick one for you now, but I would have to get the specs, run them over 8 different times for designs, then model them all and put them together for comparison and check to see which will give me the best results based on optimized output and personal preference along with staying within certain requested and uncontrollable limitations.
Its not easy for me to make recommendations without first doing a design idea, because I go all out and get very detailed, lol.
