Ported Box For An 18" Fi Btl
Would it be possible to put an FI BTL in a ported box with the max dimensions of 40"wide 25"deep and 16" high. I want to mount the woofer like this
http://i4.photobucket.com/albums/y131/NoPh33rRaCiNg/IMG_0056.jpg
because my box can only be a maximum of 16" high. Does anyone think it's possible?!?! And if you do can you send me a rough sketch of the box design!! Thx : )
Well, Fi states a recommended enclosure of 5 cf net and you got 7.60 cf to work with, so you can do it, all you need to tell me is port tuning, how many watts for the subwoofer, how much port area for the port and if you got them, the spec sheet with all the t/s parameters.
Fi audio has no t/s spec's for your sub on their website.
Heres the specs for the BTL 18
Fs: 00.0 Hz | 00.0 Hz
Re: 0.7 Ohms/coil | 1.5 Ohms/coil
Qms: 0.00 | 0.00
Qes: .00 | .00
Qts: .00 | .00
Mms: 000g | 000g
Cms: 0.00mm/N | 0.00mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 00.0 l | 00.0 l
Spl: 00.0dB 1W/1m | 00.0dB 1W/1m
Bl: 00.0 N/A | 00.0 N/A
Xmax: 16mm * | 16mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-10cuft | 5-10cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft *
I would like the box to be tuned to 38 hz. Do you think thats a good tuning??
Im going to be powering the woofer with approximately 2200-2500 watts rms
Qms: 0.00 | 0.00
Qes: .00 | .00
Qts: .00 | .00
Mms: 000g | 000g
LOL, OK, am i supposed to fill in all the blanks for the t/s parameters.
Besides, psych0ticnemes1 probably has it all covered for ya.
Fs: 32.1 Hz
Re: 1.5 Ohms/coil
Qms: 6.2
Qes: .52
Qts: .48
Mms: 307 g
Cms:.08 mm/N
Sd: 1210 cm^2
Vas: 164.2 l
Spl: 92.1 dB 1W/1m
Bl: 13.45
Try this. I think it looks right.
lambofgood91
Closet Niqqa
lambofgood91
Ocala, Florida
JG903
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
