Port tuned to 25Hz?!?!?!
truspector
I currently have a JL W3V3-2 in a sealed enclosure that pounds, however, I'd like to build and try a ported enclosure to get that extra 3db out of it. I got the plans for the recommended box of JL's website and they recommend tuning the port to 25Hz. I've never heard of tuning a port this low, usually mid 30's. Below are the specs. Anyone know why they would recommend tuning it this low, if it is a good idea, and if a pre-built box of similar dimensions tuned to 34hz would damage the speaker?
Specs
I can't explain it mechanically, but if you put that sub in a modeling program you'll see that if you tune higher (say 35) you get a BIG spike in SPL, about 4db from 45-55 hz, rolling off at about 18db/oct below 40hz making it more of a one note wonder kind of sub. Tuning low gives you a pretty flat response curve,
I was in a similar situation with my 12"
The mfg's recommendation leaned a lot more toward SPL with an Fb of 36hz. The box I built is tuned to 28hz and I really like the sound.
Right now I have the sealed box I built to the exact specs listed on that page. If I build one to the exact specs listed for the ported box will I definitely notice an SPL gain and will I lose a lot of SQ?
I don't think you'll lose SQ. The SQ you have will be about the same, but you'll gain low freq response. Seems to me, all things considered your sq will improve.
truspector
truspector
Greenwood, SC
n2audio
