Port to small for HD315?
twisztdauthorit
-db-
quickie for ya peps.
afraid i might of built my port so small for my hd315
haven't tested it yet but the port is 2.5 wide by 15.5 tall which is 38.75 in^2
This sub is a 15" and it seems like people have used much larger ports?
the box is about 4.5 cubes tuned to about 38 hz
did i screw up or will it work fine.. the edges are sanded down to reduce port noise.
**** this is gonan **** i dont have the top of the box in yet but i have 2 sides of the port wood glued in =(
any ideas on how to remove glued wood easily... its not screwed in yet. just lots of glue.
i think i can work with 4" wide which will give about 62 in^2 i know this isnt enough... but any more and i would take to much volume from the box itself....
the dimensions are 28x20x17 or around there giving me about 4.5 cubes
after sub and port that will drop below 4 cubes and the recommended is 4-4.5
im afraid i don't have much more space to sacrifice.. i wouldn't be able to slide it into my trunk if it was any bigger 8-/
its a daily driver and im not used to working with ports so large //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Any body have any alternatives?
i could always get some poly fill but im afraid this sub would blow it right out of the box
this is what my box looks like
i say put a top on it and see how it sounds, if it doesnt do it for you have someone else build you a box, and whats with that bracing?
bracing is bracing... you can never have to much..
i build my own stuff no matter how many times i need to...
im a hands on guy.
i can build another box easily, i like to do it i just need to run down and grab another slab of mdf =(
its just a hastle to redo it 8-/
ima try to cut out the port i have right now and compromise between port size and box volume...
anyone have any usefull hints?
NOTE:
that picture is older, i no have a hole cut out for the sub... the bracing is cut down to size and it looks way better than the crap u guys are looking at.... its just for size ref //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
twisztdauthorit
-db-
twisztdauthorit
Bakersfield, CA
PSturmer
