port size/ length, input and help needed
southernboom88
Shut It Down Boyz
Just wanting to double check my numbers. Just build a box for 2 sa12's, 4.11CuF after displacement, will be seeing about 1800 watts rms. this will be a daily system that i may enter in some comps. thinking tune to 33hz via aero port. I'm thinking a 6" flared port, precision port calc says it should be 13.6". does that sound right? Any input on a diff tuning or route is welcome. Thanks in advanced.
If you've already built the box and plan to put a vent inside it, you will change the internal volume of the box and thus, not get the tuning you desire... unless you do a lot of vent displacement calculations in order to find your tuning.
It's a good idea to calculate tuning, vent, sub & bracing displacement before you build the box.
But yes, that length sounds right for 33Hz if the vent doesn't change the internal volume of the box.
southernboom88
Shut It Down Boyz
southernboom88
ATL.
southernboom88
NorthFramingham
    Jun 30, 2026
