port noise?
bvr_j_0969
ok so i started building my box friday got some of the peices cut and assembled and got to looking and i think my port might be to small and cause port noise.
the box is going to be for 6 re 8's ported tuned to 30 hz. the box is 3.4 cft gross before any displacements. i was going to use 1 port 3"x8"x16" long. is this port to small for these subs? also would you do
OR
2 ports 2"X5"x15" long
this is my first ported box build and if anyone have anymore suggestions on what i could do i would appreciate(sp?) it. thanks
edit: i know i had another thread about this for aero ports but come to find out the ports i had were to big to fit in my box. sorry for any stupid questions or aggravation
my ports have to fit in a box straight and the box is 21" tall which i dont think will be possible without bending them,
how do you figure up how much sq" you have
edit im a dumbass i figure out how to get the port area, multply the width and depth of the port.
If I showed you a yard that was 10ft wide by 10ft long, how many square feet would the yard be? If you can answer this, you can answer your own question. If you can't, go back to 3rd grade.
yeah i had already figured it out i thought square inches...square is flat, so the length shouldnt matter. if i had thought about it a little more i would have figured it out.
bvr_j_0969
bvr_j_0969
kentucky
bvr_j_0969
