Port length question with WinISD
GregU
Oldschool
I'm designing a box with WinISD and I've never had to build a box with more than one port, brings me to a question.
I have to have 2 ports to keep the mach down, port dimensions are 2" x 5" ID. WinISD says that the port length would need to be 39" long. Now, does that mean that each port would need to be 39" long or 19.5" long for each port to total 39"?
This is for an IDMAX 10" = 1.75ft3 @ 27Hz
That's fu*ked up:verymad:
So whats the advantage of multiple ports?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
None, it's better/easier to do a single larger port that doesn't have to be quite as long as two smaller ports.
Well, shiet.......
Kinda hard building a box so small with such a low tune.
On ID's website they say on a 1.68ft3 @ 25Hz to make a port 3" I.D. x 17.75" long....... which is WAAAAAYYYYYY off from what WinISD says.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Well, not way off but the mach is like .24 which would whistle pretty **** bad
GregU
Oldschool
GregU
houston,tx
GregU
