Port length help
Yeah you can do that. If you can, I would put a 45 in that corner there as it will help with the air movement quite a bit
you are talking about the bottom right corner at the port correct? and which would be better? getting the length out of making it an L or adding the the maze type walls inside the port?
second question.. the bottom of the box is wider that the top as it is a wedge.. Should I make the port expand on its way down or make it the same length and width down? the reason I was thinking to expand it is so that the whole side acts as the port vs the port being on that side and there being space around it..
KyleBechtold
Quit reading this
KyleBechtold
Tampa, Florida
KyleBechtold
