BassBaller239
I'm going to build a box with an enclosure volume of 2.5 and tuned to 31hz. I have a length of port tubing that is 3" in diameter and 16" long. I was thinking of cutting it in half to make two ports. I used a calculator I found off Google and it said using two ports the length would be 12" or so. Does that mean each port is 12" or could I use the port I have and cut into equal 6" pieces?
