Port Length Forumla Help
I dont understand why you add 1.5 (1/2 of port width to connect to the middle going up). This is how I got it:
Your External Dimentions 30 x 14.5 x 19.5
19.5-.75 (board thickness)-1.5(1/2 port width)=17.25
17.25-25.5=8.25
8.25-.75(slot 1 bord thickness)-1.5(1/2 port width)=6
I dont think the 1.5 (1/2 of port width to connect to the middle going up) is right.
I could be wrong.
Okay what you are showing me makes sense, maybe somebody else can pitch in and confirm this as I am now questioning if I measuring the port length incorrectly. But now at least, thanks to you, I know that I was doing the formula correctly.
Okay so what you said got me thinking and I grabbed one of Moes Lesters designs to retest myself on how to measure port length and this is what I came up with.
18.75 - .75 (board thickness) - 1.75 (1/2 port width) = 16.25
34.75 - 16.25 = 18.5
18.5 - 1.75 (1/2 port width) = 16.75
But on that design it says that piece should be 15 inches long.
So where did the 1.75 go?
Now if you do it like how I do it, it works out.
18.5 - 1.75 (1/2 of port width to connect to the middle going over) - 1.75 (1/2 of port width to connect to the middle going up) = 15
or (if you already know your cut pieces)
13 + .75(baffle) + .75 (port piece 2s thickness) + 1.75 (1/2 of port width) = 16.25
15 + 1.75 (1/2 of port width to connect to the middle going over) + 1.75 (1/2 of port width to connect to the middle going up) = 18.5
And that is what I did before on my example, just added it up going from the beginning of the port. Because I already figured it out by subtraction to get my length for the port pieces.
Does this make sense, can someone clear this up?
berserker
cogito ergo sum
berserker
pennsylvania
Lonewolf32
