Port Length Forumla Help
berserker
cogito ergo sum
Can someone post an example of how to figure out port length? Please show how to figure out the equation in depth solving the equation.
Say a enclosure that is 3 Ft^3 tuned to 33 Hz with 39 In^2 port area.
Below is the formula I am using but ended up with answers that I know are incorrect. I thought I had it but then I read that the vb in the formula is for the boxes net volume in cubic inches not cubic feet and now I am getting odd answers. It has been a number of years since I have even figured out an algebra equation, I am getting old.
Lv = Av*1.84*10^8/[vb*1728*(Fb/0.159)^2] - 0.823*sqrt(Av)
Thanks for taking some time to help! It is going to be an l-port box. I read up on how to measure port length and I am okay with that. I just cant seem to figure out the port length formula correctly and I need to see it solved in each step of the equation (long hand is what we use to call it back when I had math classes) and I know about that online calculator, that is what I am putting the formula up against and on how I know I am messing up.
external
w x h x d
30 x 14.5 x 19.5
OK HERE WE GO
step 1: click on this link http://www.carstereo.com/help/Articles.cfm?id=31
step 2: scroll down to where it says "calculate vent length"
step 3: where it says "select your port type" click square
step 4: where it asks " is this a slot port" click yes
step 5: where it says qty of ports click how many ports there will be, in your case 1
step 6: next to where it says "enter enclosure volume" type in 3
step 7: next to where it says "enter desired tuning frequency" type in 33
step 8: where it says square vent enter the height and width of the port (note that the port width will have to be 2 inches in order for the box to be tuned to 33 hz, if you type in the 3 inches which is what you planned it will give you a length measurement that is too long for your box.
step 9: results: you should have gotten 17.24 inches
hope that helped
Not really, but thanks for taking the time to help out. This is something I already know how to do, I need someone to solve for the port length using the actual formula and show it in a step by step process on how they derived the answer.
I don’t get why you say that a 3 inch wide port won’t fit…the l-port will fit as it is only 25.52 when I use that calculator from carstereo.com
Measuring the port in the middle it will go up 17.25 inches and then over 8.25 inches and will be 25.5 total length.
If you want to do it free hand you have to remember to calculate the Radius of the port and add that to the equation you gave.. here you go:
Lv= (1.463x10^7xR^2) / (tuning frequency)^2 x (target box volume)) - 1.463 x R
For R, you will need to know you r max height of the box and subtract the wood thickness time 2.
So for example:
Max Height = 14”
Wood thickness = .75
Slot height = 14 – (.75 * 2) = 12.5”
So now calculate R for the Slott port:
R (slot) = SQRT( (slot width x slot height) / PI )
Feed R, Fs (tuning freq) and Vb (box volume) into the equation and you will get the same output as the calculator mentioned above.
Ok, so what you’re looking for is the actual length in the box, not the calculated.
You will need the following:
Lv = Port Length Calculated
Wt = Wood Thickness
Sw = Slot Width
Bd = Box Debt
Then calculate:
Sl1 = Slot length 1 = BD - ((Wt * 2) + Sw)
Actual = Wt + Sl1 + (Sw / 2)
Sl1d = Sot length 1 d = Wt + Sw
Sl2 = Slot length 2 = Lv - (Sl1 + Sl1d) + (Sw / 2)
Now this will depend on the design, lv, Bd, etc.. but you should be albe to get wha tyou want from this.
You do not need "R" in this formula, and it change Vb from ft^3 to in^3 hence the "Vb*1728"
Lv = 39*1.84*10^8/[3*1728*(33/0.159)^2]-0.823*sqrt(39)
Lv= (7176000000/223305090.778)-5.14
Lv = 26.995
I get ~1.5" more but it is due to the rounding I did. From what I understand it is better to be long than short. In your drawing the 4.5" part should be 6" to give you 8.25" to center of the 3" slot. Hope this helps
Thanks guys!
That is very close to what I got the first time until I read about Vb being in cubic inches not cubic feet, here is the post where I read that at.
http://www.caraudio.com/forum/showpost.php?p=1337542&postcount=4
Thanks, missed that lol, I see it now.
Now here is what I got the first time.
Lv = 7176000000/[5184*43075.83]-0.823*6.25
Lv = 7176000000/223305102.72-5.14
Lv = 32.14-5.14
Lv = 27
Now I rounded everything to two past the decimal point as I remember that was the way to do it… correct (because of how ours differ)? Would someone mind going over my math and making sure it is correct as I haven’t done this in a good number of years (yes I am old). Also this differs from what I get on the calculator over at carstereo.com, so what do most people go by… the formula or that calculator? Personally I would rather trust a formula, but which one is more accepted and to be true?
Moving on to measuring the length why do you say it needs to be longer can you explain that, I believe I am measuring correctly.
15 (vent side) + .75 (baffle thickness) + 1.5(1/2 of port width) = 17.25
4.5 (vent side) + .75 (vent side1s thickness) + 1.5(1/2 of port width to connect to the middle going over) + 1.5 (1/2 of port width to connect to the middle going up) = 8.25
giving me 25.5 total for port length
berserker
cogito ergo sum
berserker
pennsylvania
Lonewolf32
