port lenght
well igot these answers from roe and was wonder if i could get a conformation on these #
Originally Posted by DBDesignsElite
Square Vent:
5.07 Inches would tune you to 36 cycles.
4.48 Inches would tune you to 37 cycles.
3.39 Inches would tune you to 38 cycles.
Slot Loaded:
3.32 Inches would tune you to 36 Cycles.
2.73 Inches would tune you to 37 Cycles.
2.18 Inches would tune you to 36 Cycles.
and aswell the lenth of the port if it was only 3"x8"
box will be 36"x16.75x34.75whitch is right about 10 cubes after subs installed
subs are kicker l5 15 x2
so i have 3.5" x 15.25" port area
my ? how long does my port need to be?
would like to tune them around 36-38 h
for a 36hz tuning, you need a vent length of 5"
for a 38hz tuning, you need a vent length of 3.89"
PS: IMHO 53^2 inches of port is entirely too small for that box
The dimensions you gave ? Inside or outside ?
Inside = 10.12 feet (before port and sub)
Outside = 12.12 feet (before port and sub)
Port area = 53.375 sq “
Port length approximately 4” @ 36-38 Hz
Square Vent:
Slot Loaded:
do not use 24^2 of port either...
please elabrate (that is spelld wrong)
if you are going to use any decent amount of power on those subs, it just is too small of a port area. you will get some port noise most likely. if you HAVE to do one or the other take the 53^2.
personally, i would shoot for 75-100^2 inches
the problem i have is it is walled off from trunk (2003 impala)
and whith 2 15 that is about all the room i have
i could go to a round port but i dont see that helping me (but i dont know)
and powering them will be a zx 1500
here is link to his car
http://www.kicker.com/06/hookedup/05HUShow.cfm?ID=95051
he just sold his 12 l7 and bought the l5's
and wants them forward firing coming thriugh rear seat whith port between subs
Agreed, but I think I would shoot for more like 120 - 160 sq. inches of port. To each their own.
so should i consider aiming the subs to the rear and porting in to the cabin
or aim the port to the rear and subs into cabin
or should i leave the design alone and just try it
iowaaurora
iowaaurora
des moines iowa
iowaaurora
