Port forwarding question.. Computer ppl come hither . again
hzsogood
**The Clean South**
All the sudden while i was trying to use utorrent the download failed and said " system cannot find the specified path, and a firewall /router is limiting your network traffic, open up a port so others can connect to you.. I got the current port # for utorrent, and i am connected hardwire to my linksys router in the setting menu, under the gaming tab , looking at single port forwarding, what do i do now?
Type in the ip address of the machine utorrent is on. Name the program utor. Authroize both UTP and UDP. And you port range is the port your using; just make it the beginning and end.
ok well im in the linksys page , single port forwarding.. typed in the port # for utorrent ( 34898 )
external port: 34898
internal port 34898
protocol: set to both ( TCP/ UDP )
But heres where im stuck.. what to i put in for the "To IP address " The only thing i can change is the last numbers .. 192.168.2. Is already set, but no ending #
XP:
Start > Run ... > type cmd > ipconfig /all
Vista:
Start > type cmd in search box > ipconfig /all
You may have to Run as Administrator if, for whatever reason, you haven't disabled UAC.
To disable UAC:
Start > Type System Configuration in search box > Tools > Disable UAC > Launch
To disable the Security Center pop-up balloon telling you UAC is disabled:
Start > Type regedit in search box > HKEY_LOCAL_MACHINE > Software > Microsoft > Security Center > Edit > New DWORD Value (32-bit) > name the new item UACDisableNotify > Change the value to 1
Restart your computer, enjoy less frustration.
hzsogood
**The Clean South**
hzsogood
TX/MN
Jmac
